I need to check my crank position sensor ,My manual tells how to check the resistance ,at 68 degrees, Does this mean at at least 68 degrees or it has to be 68 degrees.
1994 225hp yamaha checks
The air temp affects the resistance reading and the specs are taken at 68 degrees, if it's 90 degrees out like it is here the readings will be off from specs a small difference in readings is ok but a drastic difference is bad.
ÂÂÂÂÂÂÂÂÂÂ
