Yahama 30H 2006 2stroke Electrical System.
  • Yahama 30H 2006 2stroke Electrical System.
    Hello im new to the world of boats,i just bought my boat loaded with yamaha 30H and i want to install an electrical system to set up my night lights.
    What i have to do? what parts should i buy? a diagram will be very helpfull!
    The 30 2 stroke has not been available here in USA since 2002. If it is same as your motor then would need number 15 (Voltage Regulator) in this diagram as well as bolts and mounting brackets Yamaha Outboard Parts 2002 30MSHA ELECTRICAL Diagram
    You would have install a battery and run a wire from regulator red wire to positive post on battery and ground wire from engine block to negitive battery post, install a inline fuse in positive wire.
      Thanks for your time.
      Which rectifier/regulator should i use for my model?its european standart
        Don't have any information or parts list on European models, not sure.
