250 ox66 stalling
  • 250 ox66 stalling
    I have an '03 vx250 3.1L. Problem just started this weekend. When coming out of the hole if I punch the throttle it starts to stall and does it several times, if I ease up on plane there is no issue. Also while running any throttle increase it wants to stall (rpm will drop from 40 to 30 for a second then back to 40) and the weirdest thing is that it stalls when hitting waves? Plugs where changed before this trip. When the issue started replaced the water separator and blub it seems to be better (dosen't stall as much) but still not running smoothly. No issue at idle just during acceleration and rough seas.
    Problem solved?
    After doing a bit of research it appears that the VST filter needs replacement!
