1. is there a tech proceedure for replaceing fuel pump and oil pump in a 1992 90 hp tlrq two stroke outboard?
2. wot for this engine is 4500-5500 rpm i can only reach 4400 trimed out i have compression tested ok cleaned carbs installed water seperator installed new cdi mod and new spark plugs the prop that is on engine is a 3x13x17 i know i can step down in pitch and gain rpm but i should be able to get aleast 5000 rpm with this prop what do you think is the problem? confused in santa cruz ca
