Hey all, new to boating and this forum.
I have a 2000 G3 with the 25hp Yamaha 4 stroke center console, and it has the 703 remote control box.
On my second trip out today, I ran into an interesting problem. The motor wouldn't shut off with the key or the emergency stop. I went to the battery, thinking that if I interrupted the circuit it would stop, but it kept running. The only way to stop it was fuel starvation.
I removed the 703 from the boat, which is going to be tough to reinstall as there is no way to reach behind and hold the nut and washer in place when reinstalling (but I will cross that bridge when I get to it).
Before I head to the dealership, is there anything else I can check? I have the 703 open and to my untrained eye the connections appear to be good.
In my seaches of the previous posts on this topic, it seems like the white wire can be a culprit. If the connections in the remote are good, where should I check on the engine? I find it hard to believe both switches are bad so my guess is it would be something between the kill switch and the motor, right?
Thanks in advance from a newby.
