High Pressure Fuel Pump?
  • High Pressure Fuel Pump?
    I am having fuel issues, I think.
    I have a 2001 225 SWS OX66.
    I connected it (the HP fuel pump) directly to the battery and I heard the pump turn but it was slow and did not sound like it could generate 35lbs of pressure.
    I put Red to Red and Blue to Black
    I already replaced a bad low pressure pump as well as the rest for safe measure so they are fine now.
    Great friggin web site.
    I would definitely like to purchase the test light to determine the codes as well as possibly the vacuum pump with gauge if not too expensive.
    Thanks in advance!
    James
    soak it overnight in WD or pb blaster to try to break loose
    reverse polarity
      Turned out to be the main relay!
