I intend to remove the oil injection from my engine. Is there a kit made to do this? If not, what is best proceedure to accomplish this task. I prefer to mix my own gasoline and oil.
Oil injection removal 2002 40hp TLRA
No there is no kit, not sure why you would want to remove it but you have to look at a C40 parts list to see if can find the block off plate, gasket and bolts to cover hole in block when you remove oil pump and oil pump drive shaft from engine, make sure you get oil injection hoses blocked off at engine intake to prevent any air leaks through hoses. Remove oil tank and wiring, mix gas with 50:1 oil mix.
