Hi to all !!
I need of help I have just purchased the engine above. It starts first time & sound ok for a while on tick over, when revving sometime misses (intermitent). When in the water it will run for a while then start missing and jump around and firing on different cylinders. Also on nearly full throttle the engine will go along very well & sound good, then after a while it then cut to firing on 1/ 2 cylinders !!!!! My mechanic has set the timing up 3 times, when setting up to ok, the engine will then start jumping all over the place !!! He has cleaned the carbs twice and still doing the same !! Mechanic tells me it could only be 2 things CDI unit has gone or.... the crank is out !?!?!? He tells me it could be either of these things Please, please, help !!!
ps - Also the ball from the fuel tank never gets hard ?? could this be the problem fuel starvation or to much, sounds like fuel goes back into the tank sometimes also ???
sticka360.
sticka360.
