Choke Requirements
  • Choke Requirements
    Please can you help me?
    Does the 250HP HPDI require a key switch with a choke? I have 2 choices for key switch. Either an old looking (metal faceplate) dual key switch with separate chokes or a newer (plastic faceplate) with push key chokes.
    The newer one looks a lot better but has an extra red wire push connection from each key but the old one only has the green/yellow/black. Where would the extra reds go to?
    By the way all my gauges 2xtacho, speedo and fuel management are all brand new.
    Many thanks.
    No HPDI don't have choke. If this is a Yamaha switch panel then the red, yellow, green and black wires go to gauges.
      Many thanks
      Trinaussie
