89 200 trim motor
  • 89 200 trim motor
    How do I remove the rear trim motor bolt? Can it even be done with motor on boat?
    You can slide the right side transom bracket over enough to remove power trim unit, you have to remove transom bolts and loosen tilt tube nut enough to slide it over.
      On a 1995 150HP Salt water Series. Is there a fuse or circut breaker on the power trim motor. If so where is it located
        It has the main fuse next to starter solenoid.
          So, not practical to try to take just the trim motor out? Take the whole assembly off then change out the motor?
            You can try it but it's hard to get to back bolt.
