Yamaha 9.9 to 15
  • Yamaha 9.9 to 15
    Hi,
    I have a yamaha 9.9 (was bought in 2000) and i wish to increase its power to 15.
    what is needed ? is the reed valve enough ? or i need to change more parts? also from where can i get the parts (must ship to EU)
    also anyone knows what model is it? or where i can find the model number?
    thanks.
    No I'm not sure what can be done to increase horsepower on it, the model number should be on side of transom bracket.
      ic. maybe someone else knows ?
        bought the reed valve, anyone knows a manual and if its hard to replace it ?
          easy as, remove the cowling, pop off the choke and throttle linkages at the plastic ends, not the adjustable ends, remove the fuel line going from the fuel filter to the carb pump, remove the 2 10mm bolts securing the carb to the block , then you will have access to the reed valve assembly, which is held in by 2 or 3 10mm bolts, remove them, you may have to gently pry the reed valve assembly out, be gentle, reassemble, shouldnt take you longer than 10 minutes.
          warning be very carefull retorquing the 2 main carb bolts, they stretch and snap very easy, been there, then you go from a very very easy job to a nightmare,
          i dont have a service manual im trying to find one myself, i beleive its the same for the 9.9/15hp models
          have a look at this, it should help
          http://www.boats.net/parts/search/Ya...AKE/parts.html
          as far as im aware looking at the parts breakdown the only difference between the 15 and the 9.9 is the reed valve, however the 15hp may also have more aggressive ignition timing, which is why a service manual would be good to confirm.
            replaced the reed valve and yesterday when i went to test it .. noticed that i had a cracked head and water was spraying into the motor :S
            could it be because of the reed valve?
              uprating 9.9
              Hi,
              New to forum; found this when considering upgrading my 9.9 to a 15. I have a workshop manual so if anyone wants some figures from this please pm me.
              Any further advice on the upgrade?
              Tim
