First I like to said hi to everyone on this forum. I am a new member. I am looking to replace the zinc that is above the prop on my 2003 F225. Can anyone help me with the procedure?
Just pop off that little black plastic cover above the zinc anode/trim tab, use a socket wrench to reach down in there and remove that bolt. Reset your new zinc to the same angle as your old one.
