Need help with 1992 90hp outboard engine
  • Need help with 1992 90hp outboard engine
    I have a 1992 90hp Yamaha 2 stroke outboard engine, I have a problem with the engine not being able to achieve wide open throttle which is 5500 the highest I can reach i 4400 rpms. I have cleaned the carbs, changed cdi module, changed the plugs does anyone have suggestions of what else I can try? Any help would be appreciated.
    Check compression, check spark to see if firing on all cylinders and look for water on spark plugs. Check fuel diaphram to see if ruptured.
