Yamaha Tachometer Erratic
  • Yamaha Tachometer Erratic
    The Yamaha Digital Tach on my 2001 F-115TLRZ started to read erratic this afternoon. The tach will jump high in RPM by 20%-50% every 5 or 6 seconds and then return to normal. No change in load or motor revs accompanies the change on rpm reading. This is ocurring at all engine speeds. I checked the connections under the dash and have not found anything which could explain what is going on. Looking for troubleshooting suggestions.
    That is probably a bad tach, try a new tach.
      Any way to tell its a bad tach before spending $350 on a new tach?
        You can connect a AC voltmeter to green wire at tach to see if signal voltage stays steady.
