yamaha 115 loss of power
  • yamaha 115 loss of power
    I have an 01 115 yamaha txrz. My motor runs great most of the day however every now and then while I am running it unexpectedly loses power. I keep the throttle in the same position and within a minute or two the power comes back. I run a 10 micron inline filter on the motor am going to replace it next weekend to see if it makes a differece. I am also running the same fuel (e 10) from last season that was stored with stabil. I am hoping to run out most of the fuel and refill with fresh to see if it is just some stale gas. I am hoping it is just a gas problem but I would appriciate any other thoughts that I might want to investigate to correct the problem. Up to this point my motor has ran flawlessly!
    Thanks in advance!
    Mike
    Check your compression to make sure you have not hurt the motor already and then drain and clean the fuel system. running lean cylinders will eat pistons
      what is the simplest way to remove the fuel from my tank.
