Replacing Piston
  • Replacing Piston
    Can i replace piston and ring no 1 just by from the cylinder head?If yes can anybody give me some tip step by step.My engine is yamaha 85hp and the no 1 cylinder is lack of compression.Diassembling the powerhead required a lot of work ,i think.tq
    no, you will need to pull power head
      ok.what is the standard turn for the needle that attached with the spring at the carburetor.some told me,screw full in than turn back out 1 1/4 turn.is it correct?
        All depends on the model # and year
          yamaha 85hp 2 stroke AE 688,year 1992 or 1993.thats all i know
