I have a 2005 225hp yamaha ob..........today I could not start the engine and at same time the trim tilt for lowering the engine did not work. I replaced both batteries with new ones. Checked all connections to batteries and cleaned and tightened the terminals. Not sure what happened but the trim worked and engine started. After a while I shut the engine and later tried to start it with no results. I am confused why both the engine won't start and tilt won't work as I thought they were on different systems. Anyone have any suggestions
