89, 8hp 2 stroke fuel delivery problem
  • 89, 8hp 2 stroke fuel delivery problem
    Hello,
    This has been a sweet running motor - always well maintained - always started two pulls on choke then off we go.
    It began to run lean and soon need full choke to stay running and soon would not run. Good spark - dry plugs - I purchased diaphrams and gaskets for the fuel pump and installed - no change - strong fuel pressure to the fuel pump block but fuel does not seem to get to the float bowl.
    I pulled the carb and inspected needle and seat - was free and looked good, no gas in the bowl. If I give a little shot of starting fluid it will fire off and quit. I don't like to do that many times on a two stroke.
    Would like some ideas from you fine folks.
    thanks ahead of time!!
    Buzz
    Sounds like you have a blockage. Take apart and clean passages and hoses
      Good advice - I have replaced the fuel line from tank to quick connect fitting on the motor and the fuel line from quick connect to the fuel pump.
      And as stated earlier I have put diaphrams and gaskets in the pump. All looks good - really perplexing.
      Question - how is fuel drawn through the pump? Vacuum?
      What makes the pump work?
      thanks
      Buzz
        I forgot to say - no difference after new lines - still good pressure to the pump block - but no fuel into the bowl.
        Buzz
          Maybe remove, disassemble and clean carb, jets, passages.
            Yup - thats my next plan - will advise.
            thanks
              And start using an Ethanol stabilizer like Startron or StaBil Marine. Also add a 10 micron filter if you don't have one. If your blockage is due to E-10 (Ethanol enhanced) fuel problems, you will be fixing it more than once if you don't get the problem solved at the source.
