200 HP VMAX Hard to Start
  • 200 HP VMAX Hard to Start
    I have a 2000 200HP VMAX 2-Stroke and after running around all day pulling skiers it will not start. Sometimes there is no noise or anything, we thought we heard clicking one time but not sure. After a little while it will crank up. Does anyone know if this because it is getting hot or other problems? If someone could give me some ideas on what to check out I would appreciate it. Thanks
    Not much info to go on , but do a voltage drop test on battery and cables to see where bad connection or cable is located
      Turn and hold your key 'ON' and then turn your steering wheel. If it catches to start then you have a broken wire in the wire housing somewhere. Also check all your in line fuses.
