dual station set up
  • dual station set up
    i'm putting dual station controls for a set of 250's and can't seem to figure out how to get them to work properly, keep getting a awarning buzzer on sb side and the pt side give a warning after i put in gear. station was purchased used with motors and i'm told everything worked great when they were taken off. any suggestions?
    Sounds like it's out of sync and need cables readjusted. Give me your email address and I can send the manual.
      I am also having the same problem with my twin OX66's with the dual station control. Has been getting progressively worse. First started when the port engine was put in reverse using the lower station controls (neutral horn sounded and would kick in and out of gear). The top station would work fine. Now it does it from both stations even just putting it in forward. . Would you be able to send any info my way? Help! Thanks. Flyskyhigh(at) yahoo.com
