I removed the lower unit in neutral and replaced the water pump. I greased everything up and installed the lower unit back on the motor. I didn't adjust anything with the shifting rod in the mean time. With everything put back together, I fired up the motor to test. Forward, reverse, and neutral were all correct and the water was flowing. The one thing i noticed was more clunking in the shifting process than i have noticed before I removed the lower unit. I have run this motor for only about 20 hours since I purchased it and never heard it clunk this profoundly. Could i have caused this? Could the shifting rod gotten moved causing more clunking to occur? I am baffled for now.
