Looking for carburetor kits for 2003 F60TLRB. Anyone have a suggestion on where to get complete kits???????????
2003 60HP 4 Stroke Carbs
I do not normally get the kits because all the parts are usually not needed. Just take apart ,clean , and order/replace only what you need.
Did you remove the plugs over the adjustment screws and the air adjustment screws last time you cleaned carbs? If not there probably is some plugging in those passages.
From what I have read the 4 Strokes have to be set after reinstalling with a 4 line manometer or other such tool and most people do not have them
