I have a Yamaha F50 with a jet leg and looking for some hlp to diagnose a problem.
The motor seems to bog a bit and not run to its potential half the time. It will on its own all of a sudden start to run properly and gain approx. 5-6 mph as I hear the engine start to run good. Then it will start to bog again and slow down, all without touching the throttle. This is very inconsistent, and seems to run the best after the motor has been run for a half hour or so.
When it runs good (20% of the time) it pulls hard as it should
I have had the carbs balanced, checked the timing and all is in spec. I have also changed the plugs and it made no difference.
I am currently running some fuel system cleaner through the engine.
I suspect there must be some crap floating around in the carb bowls?
The inconsistency of this problem has me stumped!
any help would be appreciated.
