1990 yahama 225 no spark
  • 1990 yahama 225 no spark
    i have a 1990 yahama 225 outboard that isnt producing any spark any suggestions omn what could be the problem
    I had this happen one time and spent alot of time trying to find the problem. Until I saw the wedge for the kill switch had pulled out. DUH, put the wedge back in and away she went. Hope this is the case for you
      unplug main 10 pin at motor, use brown @ start relay to turn over and check for spark then
        thanx 4 the info.how do i find out if its the stator thats bad?
          115 v4 yamaha
          Hi, I am new and I hope you can help me.
          There is absolutely no spark at the plugs.
          The killer switch is working and in.
          On the Cdi unit I have power exept at the two top incoming wires from the magnito.
          Please I need your help!
          Thank you.
