water preasure fittings on 2005 250 HPDI
  • water preasure fittings on 2005 250 HPDI
    Im looking for the yamaha part # for the water preasure fittings for a 2005 HPDI 250. The motor already has a port installed on the head, its a threaded male brass compression fitting. Im looking for the yamaha part number that corosponds to the female compression nut for that threaded fitting whitch would accept the 1/4" hose that runs to the water preasure gauge.
    Thanks, Lee
    ttt
    Any Ideas here?
      If you are using an aftermarket water pressure gauge then use MAR-WPRES-AD-TR adapter.
        No thats not the part Im looking for. What Im needing is e a copression nut siminlar to the one uses on a compression fitting on a ice maker line. Here is a picture of the male threaded fitting on the motor.
          Ok that is the Yamaha tubing, the nut and ferrule is part number 663-83668-00-00.
