Best Prop for 2000 115 V4
  • Best Prop for 2000 115 V4
    I purchased a used outboard 115 V4 (C115TLR2) earlier this year and although the engine is working great, the prop could be replaced. I'm not sure if the prop that is on it is the original, but it's damaged and doesn't feel like it's performing as good as it could.
    Any case, I've looked around at parts dealers and they list at least 20 that I could use.. Could anyone recommend the optimal prop for this engine.
    I use the boat on the ocean for transportation to and from a cottage, so top end speed is more important than the initial get up and go.
    I appreciate your help!
    you need some other factors mainly weight did the engine come off a heavier hull ?
      Look at this site And see if you can find a boat motor combination like or close to yours and see what prop they used.
      Performance Bulletin Home
