I was running most of the day at 3/4 throddle or less and ran fine. I went to WOT for about 5 min and the motor shutdown. It acted like it was starving for fuel. Pulled the cover and paint around exaust manifold had gotten hot. Went to ramp on 1/2 throddle with no problems. Got home and checked buzzer, it was week but working. Installed a temp and removed the T.stat. Took out and ran good except hearing engine noise at WOT. Thought oil inj. problem so added oil to gas and ran fine at OWT for the rest of the day. Flushin at home and noticed no water comming out of the two exaust ports but water at the prop hub. I also found the oil level in the tank lower. I assund I have a blockage in the water jacket. Am I missing something or should I start removing parts looking for blockage. Where should I start. P.S. I always have always had good water pressure at the tatle-tale.
Any thoughts would be great!!!!!
