Changed prop something looks wrong
  • Changed prop something looks wrong
    I have a 1998 Yamaha 150TLRW and I changed the prop which was a 21 pitch. This caused to engine to have to many revs at WOT so I exchanged it for a 24 pitch. After placing the thrust bearing on and then the prop the spline stop just inside the outside of the prop. The previous prop had a half inch spacer then the nut and cotter pin. Can I just put a large washer between the prop and nut?
    The thrust washer does not go inside the prop or the foot.
    Sounds like the prop is not hubbed for Yamaha or the first prop had different hub, make sure thrust washers match prop you are using.
