Hi all..I've read through a million posts about similar issues without resolution...
I have a 2003 Yamaha V150TLRB and 704 remote, perko switch, and a good battery.
Problem started with key switch fluctuations, then the relays started buzzing when I turned the key or hit the trim/tilt. Then I would turn the key, after a few second the gauges would light up, and turn the key or tilt/trim and poof, lights out, no gauges. Now, nothing at all...this all took place progressively as I describe over the course of a few days. I'm not 100% on the terminology but in the main harness, I count 8-pins, the red wire shows 12.7V (battery slightly run down) and all the other pins (even the black one) show right around 10.7V....that's where I got stumped. All fuses are good, all connections look good (that I can see)...I thought the key switch might be bad? I've seen other posts where folks seem to know what controls what and I'm going to buy a shop manual but in the meantime...can someone give me a run down of what I should be metering on the incoming harness pins, how to check the key switch (power to blue and yellow = good?)
And hopefully someone who's familiar with this issue and can point me in the right direction? I'm pretty savvy electrically, just don't know enough about this system. Thank you. Randy
