starting 1989 Pro 50 first time in two years
  • starting 1989 Pro 50 first time in two years
    Picked up 1989 Yamaha Pro50 that hadn't been started for 2 years sitting out side.
    I'm a rookie Boater but this is what I think I should do.
    1. empty fuel container and re fill with fresh gas. Should I clean out container or flush it with ;aquer thinner or something to get varnish out? pURGE BLUB AND FUEL LINES OF OLD GAS.
    2. put new plugs in.
    3. new gass filter
    4 Empty Oil reservior and replace it ( With what type of oil?)
    5.remove screw from bottom of carb bowl and spray in sea foam cleaner.
    6. spraY SEAFOAM CLEANER INTO CARBS.
    aNY SUGGESTIONS ? AM i DOING THIS RIGHT?
    Probably need to remove and clean carbs, put oil in gas until can check oil injection system is working ok.
