I pulled my boat out of storage and pulled it over to the pad to run it a little bit using rabbit ears. It started fine and the telltale (pee) flow seemed to be ok, I didn't much rev the motor up.
My question is: Should the water (at idle) shoot straight out of the telltale or should it shoot out about 2 inches and then start falling off? Hard to describe but on my Merc 60 it pretty much shoots straight out for about 5-6 inches before it starts falling off.
Also, is the water also supposed to come out of the prop area, or somewhere else?
Just wondering, it seems that the intake holes where the rabbit ears attach are pretty small compared to other motors I've had...I guess this is enough of an intake???
