I have been told by a mechanic friend that if you suspect that any debris is present in an engine that may floating around in the cooling passages you can remove the thermostat covers and thermostats and run the engine to remove the debris.
I wonder if this is a good idea or if it might cause a problem. Any comments would be appreciated.
Thanks,
happyboater
Thanks,
happyboater
