Hi there, I am new to this forum thing but i need help!!! I have a new F30 2010 and i have the Y-COP system and i cant work out how to fit it???
Can any one help please?
It connects to the Command Link network hub, if you do not have Command Link gauges installed then you would need a CL hub and main Bus lead installed.
If you do have Command Link gauges then disconnect battery cable, install YCOP and connect to hub, make sure ignition key is off and reconnect battery cable and engine ECU will sync with YCOP. YCOP.bmp
