jdflying
  • jdflying
    My 4-stroke 25hp will only run when I manually choke it by placing my hand over the air intake. Remove hand and engine dies. The primer bulb is firm. Any suggestions?
    clean the carbies must have muck on the pluck
      Thanks Mitch. I had already cleaned the carb. but overlooked the #50 jet underneath the rubber plug. This jet was plugged. After cleaning it the motor runs normal. Thanks again.
