I have a '99 200 EFI Yamie. I just pulled it out of storage. She fired up right away and ran great for about five minutes and then just stopped. Can't get it re-started. There was no pressure at the bulb, so, I replaced that and am still getting no pressure. Any suggestions? Thanks.
'99 Yamie won't start
Disconnect line from motor and pump bulb to see if it is moving fuel. Block off line and see if it firms up when pumped, if it does then like Tucker said it has to be going somewhere and if you do not see it coming out anywhere then it must be going into the crankcase from the pumps. If it does not move fuel and firm up then look at the supply side of the system, tank, bulb, and lines for air leaks or blockage/ restrictions.Last edited by 99yam40; 04-13-2010, 04:17 PM.
Originally posted by ChrisV View PostI've replaced the primer bulb, fuel filter, and all three fuel pumps. Still no pressure in the bulb. I can't figure this out, does anybody have any other suggestions? TIA.To check the line cut the connetion off the fuel line a little away from the snap on fitting to the motor and pump the bulb and see if it will draw fuel from the tank , if it draws fuel then refit the snap on connection to the hose with a ss hose clip and put it on the motor and prime the system , the bulb will take a few pumps and should be hard and then the motor should fire up almost straight away .Maybe !! Check the fuel flow direction on the bulb !! it has 2 arrows and they should be facing the motor !!
The motor probably fired up and ran on what fuel was in the system and stopped once it was dry !!Last edited by tunnels; 04-23-2010, 11:33 PM.
