I would like to add a water pressure gauge for a 2000 90TLRY. I was told we had to drill and tap the water jacket.Is this true or can someone tell me where the plug is?
2000 90tlry
No there is a water pressure port on engine to install Yamaha water pressure tubing, here is diagram.
Thanks, I found it this afternoon.The plug was very hard to get out which means when I got it out the threads were gouged.What is it that you use for that? Not a helicoil. I heard something else mentioned here. Also adding trim gauge, what is the part number for the harness that goes to the console?
Thanks for the info.
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
but seems like they are dear
I have not used them as they are not available in Australia but just the engineering is better than heli coils
ÂÂ
